Moving Parts & Sketch Entities
robert_melascaglia
Member Posts: 45 EDU
in Drawings
Good Day All
After being able to complete the bracket with post as shown; one would think copying and/or moving to another location would be easier. However, I am certainly missing something as I cannot make it happen. Please see the snip, I like to move the parts to the left at the point along the construction line, thanks.
You can use Pattern (Linear Pattern in this case, but there are also Circular pattern, Curve Pattern, and Mirror features) if you want to copy the part to an additional location, or Transform if you would like to move it.
Is this a sheet metal part? If so, Transform is not yet supported, but Pattern is.
The only way you will be able to pattern sketches is by using the "Feature Pattern" option of the Linear pattern.
There are some more general recommendations though:
