Lofting with guides that cannot pass through all profiles
tony_459
Member Posts: 206 ✭✭✭
I'm modeling the hull of a boat. For that I'm using a loft, starting from the deck of the boat and moving down through horizontal slices all the way to the keel. The shape of the boat has to be precise, so I created guides from vertical slices of the boat, taken at various points along the length axis.
...Trouble is, some of the vertical slices, and therefore some of the guides, do not pass through all of the horizontal slices (for example, because they are close to the tip of the boat and therefore hit the keel after only a few horizontal slices).
If I use those guides, I get a warning that all guides must intersect all profiles. In other words, the guides I created near the shallower ends of the boat seem invalid.
Are there any loft experts with a quick pointer on what I could try to get this loft right? The loft has to pass through the shallow guides or the results isn't usable. Thanks in advance!
I've sliced and diced and sliced and diced and sliced and diced all day and no go. My god. If I didn't care so much about this project I would have quit days ago.
I've had to touch and retouch and retouch sketches. Split lofts galore. A loft won't do for the corners? OK, let's do a fill surface and an enclose feature. Or not! OnShape gets picky, and what works for one slice of the hull will break mysteriously for the next. And when something works, it works only partially—you'll get your loft, but you can't join it to the other lofts, no matter how hard you try—not even with a boolean operation.
I'm going on four days just trying to get a decent hull, and still nothing. Jesus. A loft should be only so complicated.
I also didn't like that with so many more slices—all based on eye drawings from boat plans—the loft would be wigglier and more likely to show any errors due my limited precision. There must be a better way to do this. I've been doing CAD for years, but I've never struggled like this. Boy!
projektowanieproduktow.wordpress.com
