Duplicate mate connector on opposite side of an extrusion
tgunrtgunr Member Posts: 45 ✭✭
If I have a mate connector on one side of an extrusion how can I duplicate the exact position but located on the other side of the object? I "could" duplicate the sketch and paste it on the other side I suppose to get to the construction line that defines where I want mate connector but this seems really lame. If I could somehow reach the point that defines the X,Y then create with a new Z but I don't see how I can do that.
    edited October 2018
    @tgunr
    Does a feature mirror of the mate connector work for your case?  If not, you could feature mirror the sketch and then make a new mate connector as desired.
