Part number algorithm
svenolov_nystrom
OS Professional Posts: 84 PRO
Why not use an algorithm for automatic part number assignment. When a new dockument , part or asm is created it will be assigned a part number based on this algorithm - format 000 000 000 (or something else)
A document is numbered 000
A part studio is named as 000 300
A part get its number based on the Doc. and part studio name ex 100 300 001
ASM. and DRW numbers based on document number and a different digit in the third group ex. 100 300 200
This follows the normal process when a mechanical structure or project is built
I use this algorithm in my project manually . I have full control without a separate database ( by including the part number to the name)
It works can it bee automate?
Sven
Sven
Second, you can use the new release management to do something like that. See you Professional account settings
and last but not least...
- What happend if you want to create a new subassembly...
Usually the answer is... create special rules for a lot of specific issues that you do not want that follow the default rule.
There a few things you can improve there, but that is a great example to show the relation between part numbers and manufacturing processes.
I will try to create the same example but with a few improvements and maybe and a different approach
It was hard to make it I have great respect for Cody Armstrong and co for their tutorials.
