Bend lines
hobie_smithhobie_smith Member Posts: 35 ✭✭
Hello,
is there a possibility to adjust the bending lines?
Whether up or down, the bending line is always the same.
In the press brake, the downward direction is always used because the liners do not differ.
Can not they be changed?
Greetings Hobie
  • lanalana Onshape Employees Posts: 746 image
    @hobie_smith
    UP and Down bend lines are exported on separate layers in dxf/dwg export:
    Hope you can use that to differentiate between them.
  • hobie_smithhobie_smith Member Posts: 35 ✭✭
    Danke.
    Die Abkantpresse scheint nicht dazwischen unterscheiden zu können.
