GETTING STARTED WITH SIMULTANEOUS SHEET METAL
ROHIT_SRROHIT_SR Member Posts: 2 EDU
i can't find this arrow in work-space? this will help me to find out to measure the area in square inches.
    @ROHIT_SR
    You have to select two entities (in this case the two indicated faces) before that arrow will appear.  After you select both faces, is the arrow present?  Can you take a screenshot to show us the issue?
