difficulties with circular pattern of an opSphere
I have difficulties doing a circular pattern of operations, especially with the opSphere operation.
Don't know what's wrong and Onshape says regeneration complete. Any suggestions?
document link:
Thanks!
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
@"björn_britz"
A couple issues here. It is useful for debugging FeatureScript to use the 'monitor' functionality in the FS console. Open the console by pressing the '{✓}' at the top of the screen, and then press the "monitor" button next to the part studio you want to monitor.
By doing this I first found that there was an issue with your sketch plane definition:
I think this ends up being o.k. on the backend, but you should really be defining those as:plane(vector(0 * inch, 0 * inch, definition.Width / 4), vector(0, 0, 1));
Otherwise the x and y values of the vector are unitless and the z value has a distance unit, which is not optimal for the system.
The main problem here is the problem with the axis of the circular pattern:
It would be nice if the system could accept definition.axis as a `Line`, but unfortunately (because `circularPattern` is a feature, and `definition.axis` actually represents a selection box in circular pattern's feature dialog) you must pass a Query in for that parameter.
The easiest way to get around this would be to do something like:opFitSpline(context, id + "axis", { "points" : [origin, origin + (vector(0, 0, 1) * inch)] }); const axis = qCreatedBy(id + "axis", EntityType.EDGE);
And then use that `axis` as `definition.axis`.
Hopefully this makes sense. Let me know if you have additional questions.Jake Rosenfeld - Modeling Team1 -
@björn_britz
I took a look at your document, and it looks like you're trying to do these boolean operations on `opExtrude`? `opExtrude` does not have a boolean option. The `extrude` function (and therefore the extrude feature of the part studio) has those boolean options by way of first calling `opExtrude` to make the necessary extrusions, and then `opBoolean` to to boolean everything together. You could switch to using `extrude` if you want, but my suggestion would just be to collect all the bodies you want to joint together and call `opBoolean` on them.
Take note that if the bearings and the retaining ring only touch at one point, the boolean will fail because of that singularity (this would be a non-manifold body, which we do not support). You may have to overbuild the spheres if this is the case.Jake Rosenfeld - Modeling Team5
getRemainderPatternTransform
https://cad.onshape.com/FsDoc/library.html#getRemainderPatternTransform-Context-mapIR for AS/NZS 1100
Oops! sorry about that! Yes, 4 instances at 360 degrees with equal spacing ON is the same as 4 instances at 90 degrees with equal spacing OFF (if that makes sense). Basically equal spacing chooses whether the instances are all spaced between 0 and `angle` (ON) or each spaced at `angle` further than the last (OFF).
