difficulties with circular pattern of an opSphere
björn_britzbjörn_britz Member Posts: 14 EDU
I have difficulties doing a circular pattern of operations, especially with the opSphere operation.
Don't know what's wrong and Onshape says regeneration complete. Any suggestions?
document link:
Thanks!
    edited October 2018 Answer ✓
    @"björn_britz"
    A couple issues here.  It is useful for debugging FeatureScript to use the 'monitor' functionality in the FS console.  Open the console by pressing the '{✓}' at the top of the screen, and then press the "monitor" button next to the part studio you want to monitor.
    By doing this I first found that there was an issue with your sketch plane definition:
    I think this ends up being o.k. on the backend, but you should really be defining those as:
    plane(vector(0 * inch, 0 * inch, definition.Width / 4), vector(0, 0, 1));
    Otherwise the x and y values of the vector are unitless and the z value has a distance unit, which is not optimal for the system.
    The main problem here is the problem with the axis of the circular pattern:
    It would be nice if the system could accept definition.axis as a `Line`, but unfortunately (because `circularPattern` is a feature, and `definition.axis` actually represents a selection box in circular pattern's feature dialog) you must pass a Query in for that parameter.
    The easiest way to get around this would be to do something like:
    opFitSpline(context, id + "axis", { "points" : [origin, origin + (vector(0, 0, 1) * inch)] });
    const axis = qCreatedBy(id + "axis", EntityType.EDGE);
    And then use that `axis` as `definition.axis`.
    Hopefully this makes sense.  Let me know if you have additional questions.
    Try looking up the documentation of getRemainderPatternTransform https://cad.onshape.com/FsDoc/library.html#getRemainderPatternTransform-Context-map
    @"björn_britz"
  • björn_britzbjörn_britz Member Posts: 14 EDU
    Thank you! it works just fine now.
    But I also had to set the parameter "equalSpace" : true for the pattern.
    @"björn_britz"
    Oops! sorry about that!  Yes, 4 instances at 360 degrees with equal spacing ON is the same as 4 instances at 90 degrees with equal spacing OFF (if that makes sense).  Basically equal spacing chooses whether the instances are all spaced between 0 and `angle` (ON) or each spaced at `angle` further than the last (OFF).
    Now I'm trying to merge parts 1,2,3 and 4. I tried with "defaultScope": false and "booleanScope": Query but I couldn't manage to make it work. Any suggestions?
    oh right, my bad.
    It works now!
    Great to hear!
