How to use regenError?
DSPuzzles
Member Posts: 17 EDU
I am trying to write a feature with error detection, and I'm trying to use regenError to highlight a query in red when it doesn't comply with the required selection. The code I am using is:
throw regenError(ERROR_STRING, ["distEnts"]);
Where "distEnts" corresponds to "definition.distEnts", the query in question. This is not highlighting the query in red though, what am I doing wrong?
Thanks.
Thanks.
Jake_Rosenfeld
Hi @Disousa
The query box will only highlight in red when it is not the selected box. So, if you get the feature to be in a state where this error is being thrown, and then select a different query box, the query you are calling out will be in red. The query box will stay blue as long as it is selected, though.Jake Rosenfeld - Modeling Team5
