Trying to loft profile.
in General
I have been trying to loft profile sketch 9 to profile sketch 10. I obviously am new at lofting and need some help. Any suggestions would be appreciated. I am guessing I need a guide or a path but really have no idea how to add them.
Thank you in advance.
https://cad.onshape.com/documents/03f4b8dc99caf5cca95e7994/w/0cbcffe3934e27f1df113604/e/4eef5fdd203683c081b46926
TimRice Member, Moderator, Onshape Employees Posts: 315
John, I would recommend using the 3d spline feature to create guide curves between profiles. In general, you should keep the number of vertices on the start and end profiles as similar as possible. Guide curves can help in cases where you have differing number of vertices and you want more control over the curvature.
Here is my quick attempt: https://cad.onshape.com/documents/7a642d40ffd8a70df721a756/w/0b9b7145c9e10e23e70d1142/e/3f4af29af98866ab9342b2e8Tim Rice | User Experience | Support
Onshape, Inc.1
Onshape, Inc.
Thank you again.
Onshape, Inc.
