cant add holes in flat pattern
karen_wagner223
karen_wagner223 Member Posts: 30 ✭✭
I am trying to get parts into OnShape while I have a minute so we can transition from SWKS.
I'm trying to add holes with the hole feature in the flat pattern, Hole feature isn't recognizing the sketch points.
Any comments appreciated.
  • lana
    lana Onshape Employees Posts: 777 image
    edited October 2018 Answer ✓
    Hole does not support sheet metal flat pattern input. Please file an improvement request , if you need this functionality. In meantime placing holes in folded model should work. Cylindrical cut in flat pattern would work also, but you would not get hole annotations in drawings this way.
  • karen_wagner223
    Thanks Lana, I suspected this was the answer. I will submit a request.
  • lana
  • karen_wagner223
  • MBartlett21
    MBartlett21 Member, OS Professional, Developers Posts: 2,064 ✭✭✭✭✭
    @lana
    If this is implemented, will the transform from flat to model be a function that other people's FeatureScripts could use?
  • lana
    @mbartlett21
    We'll try to expose some level of utility for operations in sheet metal flat to Feature Script, not necessarily simultaneously with implementing support for holes, though.
  • MBartlett21
    Thanks!
  • kent_henderson
    kent_henderson Member Posts: 71 ✭✭✭
    edited November 2018
    I personally can't think where I would need to use the hole functionality in the flat pattern. However, we do extrude cuts in the flat pattern. An example would be in a firepit ring where were doing a custom logo for a customer.
  • bill_daniels
    bill_daniels Member Posts: 284 ✭✭✭
    I need to add holes in the flat pattern - or at least make the sketched points visible in the 3D model.
  • Jake_Rosenfeld
    Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646 image
    @bill_daniels
    You can cut holes in the flat using flat sketch and extrusion.  Do you need the hole feature specifically? The missing functionality here is that without the hole feature there are no callouts in the drawing.
