Library of Standard Fittings
I am designing a 1.5" tubular steel frame and wonder if Onshape has a library of typical fittings that I can pick and choose?  Thanks for your assistance.  RjM
  • Marc_MillerMarc_Miller Member Posts: 111 ✭✭✭
    There are standard tube shapes (and you can add your own custom shapes) in the Beams feature script, but I haven't seen any sort of fittings.  Do you have an example of a typical fitting you use?
