Switch statement
john_mcclaryjohn_mcclary Member, Developers Posts: 2,378 PRO
Is there an equivalent way of doing switch statements in FS?
instead of a bunch of if-else statements
  • ilya_baranilya_baran Posts: 963
    Accepted Answer
    There are indeed cases when a switch statement makes things simpler, but in this case, you could get a similar effect by doing:
    const table = {
    Ilya Baran \ Director, Architecture and FeatureScript \ Onshape Inc
  • Jake_RosenfeldJake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,470
    @john_mcclary @konstantin_shiriazdanov
    @ilya_baran informs me that there is a switch-expression in FS that we may document for public use in the future.  It is slightly different from a switch-statement in that it does not switch on an expression and then execute a block of code (a statement), but rather switches on an expression and then return another specified expression.  This can be made to act like a traditional switch statement using lambdas if desired.
    Here is an example:
    https://cad.onshape.com/documents/f6780441494046f4439a8219/w/71e7c5c95c521d8716fa75fa/e/631535138fdaba3ef7928ea2
  • konstantin_shiriazdanovkonstantin_shiriazdanov Member Posts: 959 ✭✭✭✭✭
    @Jake_Rosenfeld so this switch is a function, I beleve Ilya wrote it half an hour ago)
  • john_mcclaryjohn_mcclary Member, Developers Posts: 2,378 PRO
    edited August 2018
    @Jake_Rosenfeld well I suppose that is similar to a switch statement, but it doesn't allow flow through multiple cases, and it still requires many lines of code.
    y = 3;
    switch(x)
    case 0: y++;
    case 1: y++;
    case 2: y++; break;
    case 3: y = 10; break;
    default: y = 0;
    X = 0 -> Y = 6;
    X = 1 -> Y = 5;
    X = 2 -> Y = 4;
    X = 3 -> Y = 10;
    X = 4 -> Y = 0;
    Not that I end up using that method very often, but it is a traditional syntax for switch which I have taken advantage of before.
    What brought this on was I had a long list of if-else statements to fill in all the keyway sizes given a shaft diameter.
    it ended up being 500 lines of code that is ugly to read.
    if they were switch statements it would only be around 100 or so lines of code and resemble a readable table.
    Vrs:
    case 7/8: KeySeat = .771; KeyWay = .900; break;
    case 15/16: KeySeat = .796; KeyWay = 1.051; break;
    case 1: KeySeat = .859; KeyWay = 1.114; break;
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 963
    Accepted Answer
    const table = {
    Thanks @ilya_baran  That's what I'm looking for for this use case
    Went from 465 lines of code down to 189 with that
    I'll know better next time :)
  • MBartlett21MBartlett21 Member Posts: 1,752 EDU
    @Jake_Rosenfeld
    Can you specify a default with that switch statement?
    MB - I make FeatureScripts:View FeatureScripts
    think that is what the if(entry == undefined) is doing
