Improvements to Onshape - November 9th, 2018
Excellent, already putting these to good use today.0
You guys rock! Great updates. Its crazy what gets pumped out every 3 weeks. Incredible!1
En este enlace podéis ver las Novedades de Onshape en español
https://www.youtube.com/watch?v=sDMJXzI-jdw
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común3 -
Le lien suivant vous permet de découvrir les nouveautés d'Onshape en français!
https://youtu.be/f0wSaMNLYgE
2 -
Great improvements again!
What about now the possibility to replace an assembly within an assembly?
Encore de belles améliorations!
Pourquoi pas maintenant la possibilité de remplacer des assemblages dans des assemblages?3 -
On the replace parts feature - OnShape needs to add ability to replace...
1. assemblies with parts
2. parts with assemblies
3. assemblies with assemblies
this feature only replaces "part" with "part"
plus....the resolution of mates (which you stated OnShape is already working on)5 -
+1steven_elliott555 said:On the replace parts feature - OnShape needs to add ability to replace...
plus....the resolution of mates (which you stated OnShape is already working on)4 -
plus....the resolution of mates (which you stated OnShape is already working on)2 -
Great update!+1 for replace an assembly within an assembly, etc.
www.vierhoutengineering.nlMechanical Structural Engineering1 -
Please let users continue using stable versions instead of forcing updates on them. I experienced that the last App for android crashed continuously.-3
@rune_thorsen , Can you open a support ticket or provide more information about the crash you are experiencing ?0
