scroll down bar in custom feature script window
Hello,
currently I am creating custom feature script for pins, where all pin parameters are typed by user. So there is a lot parameters required. When working on computer with small screen I can't see them all.
Is there a way to create there scroll down bar?
On the left is what I see on my PC screen, and on the right is what I should see:
    @urszula_wachulska
    There is currently no way to add a scroll bar to a custom feature.  The current workaround we tell users to use is to make "pages" using a HORIZONTAL_ENUM.  Specified FeatureScript parameters are preserved even when they are not being shown in the dialog, so if you add "Page 1" "Page 2" "Page 3" tabs after the "Din" "Headless" "Custom" tabs, you can separate your parameters into multiple pages that are only shown one at a time.
    I can make an example if I haven't been clear enough.
  • urszula_wachulskaurszula_wachulska Member Posts: 21 PRO
    It is clear enough, thank you.
