Profile angle for sheet metal part
callum_ellis
Member Posts: 11 EDU
Hi guys,
I have run in to a problem I haven't experienced before and I am sure there is a straight forward procedure - hoping someone can point me in the right direction.
Would like to change the angle of this if possible, it is a sheet metal part. Please find the link here: https://cad.onshape.com/documents/749395d33e5af6d6e2b3f391/w/6e939c6a82b03e8b1587af21/e/12ad21a67d3aa0e4c9d315d8
Thanks in advance!
Thanks in advance!
Hopefully I am interpreting your question correctly. Is this what you are looking for?
Here I am using a move face - rotate to accomplish the task.
https://cad.onshape.com/documents/830cf78f34a02756be6c9978/w/e70a4869939e90b61fef87ce/e/e3039a4f904fdbe3b7c7437b
