iphone app - extrude from sketch
AlexArevalo416AlexArevalo416 Member Posts: 7 ✭✭
it would be a nice workflow if we could press extrude from the sketch command and onshape extrude from the active sketch.  this is possible on the browser not on the iphone from what I could find.  second best would be if you exit sketch and selecting extrude automatically uses the last sketch created as default as this seems to be most common workflow
    rbaekrbaek Moderator, Onshape Employees, Developers Posts: 77
    Hi @AlphaBlu, currently on the iOS app, you can extrude a sketch by selecting a profile, and then doing a 2 finger tap to open the context menu, from which you can do an extrude or revolve.
    We're welcome to any suggestions you may have on what we can do better on the iOS app, as we are still in beta and are continuously improving the Onshape experience on mobile.
    this works for me @rbaek .  thanks!
