resizeing assembly
ref3t_shref3t_sh Member Posts: 2
hi i have a question about adding a public assembly from insert parts and assembily - other documents - public then i have searches dor nema 23 motor i added it to assebly which i have added a body in it but i can't resize the body lenght so what should i do
  • mthiesmeyermthiesmeyer Onshape Employees Posts: 115 image
    @ref3t_sh
    If you would like to modify geometry from a public document you could:
    • Make a copy of the document and link to that after making the required geometry changes.
    or
    • Link to the Assembly in your document
    • Create Part Studio in context
    • Use Transform -> Copy in place and select all parts to copy the imported geometry
    • Make the edits that you want and then insert those parts back into your assembly
    • Delete the link to the public document in your assembly
    Best,
    Mike
