Creating Separate Parts from a Single Part Drawing? (Splitting a Part)
jeremy_bibbeejeremy_bibbee Member Posts: 2
Hello everyone! I have a part that is a single piece, but because my 3D printer has a build volume that isn't large enough, I would like to make the part into three pieces. Is that possible to do?
I tried using the Split Part function but nothing happened when I went through the selections and clicked the green check mark.
Thanks for any help!
  • mthiesmeyermthiesmeyer Onshape Employees Posts: 115 image
    Hi @jeremy_bibbee,
    Please see the attached gif of what I see when I split a part. Is this not what you're seeing? Can you add a link to your document here? If not, you might find our help for split here useful.
    Best,
    Mike
