How to make a Hole Feature involving variable & formula?
amir_sarigamir_sarig Member Posts: 4
edited January 2019 in Community Support
Hello,
I wonder if it is possible to give a hole a diameter dimention driven by a variable.
The feature accepts the statement " #ShaftD " (variable) alone, but it rejects any formula with it.
The idea is to keep the information about the nominal shaft diameter, and choose how much clearance I want.
Thanks!
  • michael_mcclainmichael_mcclain Member Posts: 198 PRO
    Add units to the 0.2 value or it can't determine whether it's in or mm. When in doubt, manually add in the unit to the value and the formula should work
  • amir_sarigamir_sarig Member Posts: 4
    Works!
