Access the version name via a global variable or feature script
fredrik_tärnell
Posts: 29 ✭✭
Would like to make an embossed text on my part with the versionname for an highly iterative process 3d printing and making small adjustments in between.
I cannot tell the different versions apart by looking at the. Possible today already??
This is not possible and we have no plans to make it possible: we don't want users to worry about geometry changes when you create or rename a version or copy a workspace. You can use a local variable for this which you edit.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc-2
https://forum.onshape.com/discussion/3780/how-can-i-include-a-variable-value-in-a-sketch-text
And the follow up feature request
https://forum.onshape.com/discussion/3796/variable-values-displayed-in-text
Doesn't seem to have passed critical mass yet?
1 -
The requests you link to are for using variable values in sketch text -- that is already possible with FS and we do have plans to enable this without using FS.
The part of your request that is problematic is using a version name as a variable: a fundamental aspect of Onshape's design is that once you've created a version, you have nailed down the geometry (referencing, release management, caching, etc. all depend on this). So there's no way a version rename could alter the geometry in that version. What I can imagine happening at one point that would address your need is if we simplify the use of the API to the point where it's suitable for general individual use: then you could write a function that first modifies your part studio sketch text with the intended version name and then immediately creates a version with that name.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc-1
