Shower Nozzle, Linear Pattern
famadorian
Member Posts: 390 ✭✭✭
For a shower nozzle, I want to create a linear pattern.
Can such a pattern be created from the center and then bidirectional?
The nozzle has 7 rows and 8 columns.
Here's my drawing: https://cad.onshape.com/documents/496067d2ccbc9b881a8ff3c4/w/8d013e8e1b9b365bdd486f87/e/70e2447a06b6735ee49f5130
Optionssebastian_glanzner Member, Developers Posts: 401 PRO@famadorian
You can do that:- Create a sketch and place a center point rectangle
- Dimension the distances to the outer edges (I also created constraints so it is in the center)
- Change the lines of the rectangle to construction lines
- Create a circle at the lower left corner (this will be the hole)
- Use the circle for a linear pattern in the sketch (with the number of holes for each direction)
- Change the dimensions of the linear pattern to "driven dimensions"
- Now make the top right circle coincident with the top right point of the rectangle
- Change the two middle circles to construction lines
- Extrude the complete sketch (don't select every circle, just select the sketch in the browser)
- Finish!
Here is the document:
https://cad.onshape.com/documents/0a591a61ad2f8d8f4477e4ff/w/a39fcd79860790f02953961b/e/78f246ea08dcc8fe75cf1b06
5
(You should probably use face mirror rather than feature mirror, as it is faster)
You can do that:
Maybe it's the best solution, but I'll read when I get home
