Shower Nozzle, Linear Pattern
famadorianfamadorian Member Posts: 390 ✭✭✭
For a shower nozzle, I want to create a linear pattern.
Can such a pattern be created from the center and then bidirectional?
The nozzle has 7 rows and 8 columns.
Here's my drawing: https://cad.onshape.com/documents/496067d2ccbc9b881a8ff3c4/w/8d013e8e1b9b365bdd486f87/e/70e2447a06b6735ee49f5130
    You can use a mirror feature after your linear pattern
    (You should probably use face mirror rather than feature mirror, as it is faster)
    edited January 2019
    Many options, I'd possibly use a standard linear pattern and then a delete face to remove the two unwanted centre holes.
  • famadorianfamadorian Member Posts: 390 ✭✭✭
    edited January 2019
    Wow, I opened this on my mobile and accidently hit accept solution. I haven't read it yet ;)  Can I remove my accept? ;)
    Maybe it's the best solution, but I'll read when I get home ;)
