Importing .SVG Into a Part Studio
Luke_Chase
Luke_Chase Member Posts: 8 EDU
Can you import .SVG files into a plane in a part studio? I need to make something match an image/logo so I converted it to a .SVG, but I can't figure out how to put it into a part studio so I can do an extrude on it.
  • kevin_o_toole_1
    kevin_o_toole_1 Onshape Employees, Developers, HDM Posts: 565 image
    Also, if you want to import the SVG as sketch lines (rather than an image), you can convert to DXF and insert that.
  • famadorian
    famadorian Member Posts: 390 ✭✭✭
    Will SVG be supported? It's not like we don't have the math for it.
  • MBartlett21
    MBartlett21 Member, OS Professional, Developers Posts: 2,064 ✭✭✭✭✭
    You can try converting it to dxf/dwg and then importing it
  • place_high
    place_high Member Posts: 5
    The online converters all suck, they always mess up part of the graph. Plus DXF are really not popular to export to for typical 2d software, and by default cannot be previewed on Mac/Windows. Can you add direct SVG support?
  • maruel
    maruel Member Posts: 3
    I used Inkscape successfully to do the conversion. It is a free open source software.
    1. In Inkscape, Open the SVG
    2. "Save As" with format "Desktop Cutting Plotter (AutoCAD DXF R14) (*.dxf)", then chose "mm" as Base unit and "UTF-8" as Character Encoding.
    3. In OnShape, create a Sketch
    4. "Insert a DXF or DWG file"
    5. Click "Import..." and select your file.
    You should be good to go from there!
  • corey_mcguire
    corey_mcguire Member Posts: 5 ✭✭
    No one doubts that a powerful intermediate program is a useful workflow.  We are all saying it is an unnecessary workflow. SVG should be supported natively.
    I love Inkscape, but inserting it in this workflow is unnecessary. SVG is a 23yo format.
  • robert_scott_jr_
    robert_scott_jr_ Member Posts: 898 ✭✭✭
    Inkscape also has different file formats available via Export. - Scotty
  • liz_eidsness
    liz_eidsness Member Posts: 2
    in case anyone finds this later - I too found this frustrating, but found another post with a different angle that helped me.
    Creating a sketch from a face, with edges imported — Onshape
    I import my dxf into new sketch. In my case it's an outline of a shape, so it has a face, but none of the points are connected (all blue). Save this.
    Create a second sketch. I'm a newbie so i had to search for it, but select "Use" tool. and pick the face of the first sketch.
    After some time, the face, and properly coincident points are nice and black in second sketch.
    Happy dance - it's the little things. Hope it helps someone.
  • martin_kopplow
    martin_kopplow Member Posts: 1,608 PRO
    So you based a new sketch on the old one to get all points black, but what if you move one of the blue points in the older sketch? Wouldn't that still destroy your model?
