Learning Center Support
KatieHuffman
Use this category to get help with exercises in the Learning Center, request improvements to enhance your learning experience, and report outdated material. If you are having trouble with an exercise, please provide the course, exercise title, and description of the issue.
@KatieHuffman
The preview image for this course: https://learn.onshape.com/courses/fundamentals-navigating-onshape
is outdated0 -
Also, in the course on detailed drawings, the tutorials on dimensioning is outdated.0
@mbartlett21 Thank you for the report. The preview image is updated, the detailed drawings course is on our to-do list to update.0
Hi katiehuffman, i finished the Onshape fundamentals of data management in some past day, I am waiting you release the certificate, but I have seen any releasing for its certificate.
Jake Rosenfeld - Modeling Team0
@thong_van_nguyen you should be all set now. You might have accidentally skipped the survey by clicking the next page arrow instead of the next question button, which will keep your certificate in a pending state. I manually granted you the survey anyway. You should have received an email notification and should see the certificate on your training dashboard.
Thanks Katie and Jake, I got the second certificate. Thanks so much Onshape team..0
@KatieHuffman
Don't know if I'm missing something: I'm trying to find the Assembly Documents to follow along in this Learning Center course
https://learn.onshape.com/learn/course/fundamentals-onshape-assemblies/mating-assembly-components/onshape-mate-types
Could you please assist?0 -
@justin_36 each document you need for an exercise can be accessed from the link in Step 1. You can then copy the public document to complete the exercise.0
Hi Guys, in the Fundamentals 3 (very last exercise) you have a large project to make the STEP out of Nylon. I have gone over everything step by step and can't find my discrepancy from your course outline. Yet when I get to the end my Mass is different from all of the 4 choices you offer. Because I have no good way to determine where my error is can you please let me know at what point my mass varies from your mass. That will allow me to zero in on where my mistake is. I am using rollback to jump to various spots and report Mass each time a new sketch is drawn.
Roll to #2 Sketch: 5.072, Roll to #3 Sketch: 0.896, Roll to #4 Sketch: 1.192, Roll to #5 Sketch: 1.257, Roll to #6 Sketch: 1.418, Roll to #7 Sketch: 1.416, Roll to END: 1.4030 -
@christopher_moore072 the discrepancy seems to be between your sketch 4 and 5. You do have access to the completed public document in the self-check question. Just copy the document so you can rollback.0
Thanks Katie, the issue was that I had the first draft going the wrong way I was looking at the directions instead of checking in transparent view what the profile looked like on the draft. So guys be sure to check things from the side and ensure that your drafts are going in the proper direction.0
In Fundamentals 5: Onshape Assemblies / 02 Mating Assembly Components / Exercise: Basic Assembly / Step 10, the screenshot shows a section view of the cylinder to reveal its bottom inside face where a mate connection point is needed.
How can I create that section view?
Thanks.
hi joel_shprentz,
Please look at the section titled View parts sectioned with Section view here: https://cad.onshape.com/help/#moving.htm
and if you need to move it, you can use the manipulators
Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com0 -
Here's an OnShape video that doesn't match the behavior in OnShape and a discussion of same...
https://learn.onshape.com/learn/course/fundamentals-sketching/sketch-constraints/dimensions
https://forum.onshape.com/discussion/comment/38545#Comment_38545
Thanks, jakeramsley. Your example and the linked help showed me how to use the section view.
@larry_hawes Thank you for pointing this out, we'll fix the video as soon as possible, as it is now the Enter key not the Tab key to switch dimensions.0
@KatieHuffmanHi Katie,During the past 10 days, I completed 2 "Learning Pathway":- Onshape Fundamentals: CAD- Onshape Fundamentals: Data ManagementThank you for this interesting training.My question is :I received a Certificate of Completion.why the Certificate does not have a reference number? License number?Also,I am interested in further training which are related to educators. Do you have a training for the trainers (ToT)?Thank you,Hisham0
@hisham_ramadan curremtly we do not issue certificate reference or license numbers, but this is something we are looking into.
We do have a college curriculum that you can reference and use for your class.
Thanks!1 -
Hi, this is Tony, I am currently going through fundamental path in learning center. I am struggling with this step:
https://learn.onshape.com/learn/course/fundamentals-part-design-using-part-studios/creating-draft-shell-and-rib-features/exercise-step?page=2
It is a excise on creating Draft, Shell and rib features(create a step), I have difficulty recreating Slide 15/30
My work is located here:
https://cad.onshape.com/documents/1b7257a912b905482976f51a/w/c3e2320d9c1e6f4ea5d06847/e/0965c0bbf9889fd381379dc1
Would you please give me some guidance where I made mistakes? I have tried to remake this object twice stuck on the same step.
Thanks!0 -
Hi @tony_yang568
Sorry you're having difficulties!
On slide 14 it says that you should be making your sketch on the "Right plane". Your sketch is on a face of your part, whereas the instructions are trying to tell you to place the sketch on the "Right" default plane. When sketched correctly this looks like:
Jake Rosenfeld - Modeling Team0 -
Nice Jake,
I was going through the exercise and didn't run into any problems but appreciate you taking the time to spot the error.1 -
Thanks Jack, I am speechless...and embarrassed ..should've gone out for a walk first..lol1
Currently working through this page
https://learn.onshape.com/learn/course/managed-in-context-design/what-is-managed-in-context-design/exercise-step-stool-creating-contexts?page=2
When selecting the hole that that shares the sketch plane to use the edge in my sketch OnShape tells me that it could not project the selected entities into the current sketch. I can use the edge of the other hole on the other step with not problems. i was able to select the edge of the hole that wasn't on the sketch plane though.
@Eric_Gobrecht that is a tricky edge to select and I have made a bug report for it. Using the back edge is okay for the exercise, and gives the same results. You can use select other to choose the front edge.
hey guys
I am very new to using any cad type program. I am currently doing the parts design using the parts studio course and I cannot seem to get the rim to extrude, on slide 19. Any ideas on what i may be doing wrong??
Thanks Spencer0 -
https://cad.onshape.com/documents/9bbccc87a80b993196b395a4/w/a62817943487cbf89195751a/e/8932ccf17b49eee0e17ae24b
does this work? how do i do a screen shot??ha0 -
If you hover over feature name, a tool tip would tell you more.0 -
@spencer_hazelwood
it looks like you have the incorrect sketch profile selected to cut with. Remember you are just using the outside-most profile of the main sketch to extrude remove.0
