extending Neil Cooke 's port feature won't work
tonvistonvis Member Posts: 41 ✭✭
https://cad.onshape.com/documents/537978ffd6db628ae304a014/w/c4df816f6f58ef48a64f3b91/e/2faa916019fd524dd61d27ac
Can someone please helpme out.  Selecting other enums will not work , only the last in a row gets  selected.
I tryed everything but I can't  find any mistake.
Part of code:
annotation { "Feature Type Name" : "Ports_generator",
        "Feature Name Template" : "#screwtype Screw",
        "Editing Logic Function" : "editPortLogic" }
//export const portFeature = defineFeature(function(context is Context, id is Id, definition is map)
export const Ports_generator = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "Screw" }
        definition.screw is ScrewType;
       // no way to get this "SAE " enum done !, BSP  dimensions will always be selected
        if (definition.screw == ScrewType.SAE)
            annotation { "Name" : "SAE" }
            definition.portSize is PortSize;
        if (definition.screw == ScrewType.BSP)
            annotation { "Name" : "BSP " }
            definition.bspportSize is BSPPortSize;
        annotation { "Name" : "Points", "Filter" : EntityType.VERTEX }
        definition.points is Query;
        annotation { "Name" : "Depth" }
        isLength(definition.depth, DEPTH_BOUNDS);
Many thanks for your help.
tonvis
  • lanalana Onshape Employees Posts: 746 image
    edited January 2019
    I think, you want this in precondition
    while your feature studio has this
  • tonvistonvis Member Posts: 41 ✭✭
    Lana thanks for your help.
    You are right ,this is my fault. Due to many trials I made a typing  error  there .But correcting the feature according your comment does not help to solve the problem. There is something else going wrong. I am looking in all kind of feature scripts  for over a week, but can't find the solution.
    Selection another enum will not activated , and there is no error message.
    Can you please give it another eye.
    https://cad.onshape.com/documents/537978ffd6db628ae304a014/w/c4df816f6f58ef48a64f3b91/e/de74c96ae6e157189c9be65d
    Best regards
    tonvis
