No merge scope selected
dan_wolfe067
Member Posts: 8 ✭✭
How do I select a merge scope?
Optionsowen_sparks Member, Developers Posts: 2,660 PROHi.There will be a box on your feature input, usually at the bottom, that selects which part you want to act on. So if it's a hole, what do you want the hole in, if its an extrude with the add to existing part option selected then it's asking which part to add to.Is that clear? If not a screen grab will be in orderCheers, Owen SBusiness Systems and Configuration Controller
HWM-Water Ltd7
