Adding guides and offset to extrude fnc.
bari
Member Posts: 9 EDU
Adding these two opptions would make the extrude tool far more powerful,
Guide lines would save a lot of lofts, (which usually need another plan and sketch.)
Same for the extrude with offset. Saves planes and makes the design more elegant.
However, the 'Guide line' would allow you to extrude in a direction that in not necessarily normal to the sketch plane....this functionality in SolidWorks is quite useful. "Extrusion Direction" or something like that. With nothing selected, the extrusion is normal to the sketch plane. With an edge (or line) selected, the extrusion direction is parallel to the edge or line. With a plane selected, the extrusion direction is normal to that plane.
