LOFT TROUBLE
alex_drialex_dri Member Posts: 3
GUYS,learning onshape slowly,trying to recreate this loft
https://www.youtube.com/watch?v=Ho9tbC-gU9w
turns out like this-my loft fails when i choose path as scetch 1 and 4
https://cad.onshape.com/documents/6fe8dd75da41155dae4605b3/w/9525334601771697bb7d0ccd/e/6623d4bbbeea6ca7a5e286ce
any help really appreciated)
  • alex_drialex_dri Member Posts: 3
    edited February 2019
    TimRice said:
    Welcome to the forum @alex_dri !
    I took a look at your document and found a couple of issues. As you can see in the screenshot below, the guide curves did not intersect the profiles:
    [IMAGE]
    Next, the guides had to be split in two using a Split tool in the sketch:
    [IMAGE]
    And now it all checks out!
    [IMAGE]
    Thanks,TimRice!
    I would never have guessed about split guide line)
    Also same sketch has only 2 handles(start and finish point) to control curvature,how can  I get handles in other points?
  • TimRiceTimRice Member, Moderator, Onshape Employees Posts: 315
    Currently spline control handles can only be placed at the start and end points.
    Onshape, Inc.
    @alex_dri
    If you make a bunch of splines, you can apply a coincident constraint on their endpoints to attach them, and then a tangent constriant to make them tangent to each other.  Then each point will have a handle:
    One thing that may not be obvious in the gif is that I am double clicking to end each spline segment, which also keeps the tool open to sketch the next spline segment.
