Is there a way to get the local transformation matrix instead of the global one?
C_JustinC_Justin Member Posts: 16
Is there a way to get the local transformation matrix instead of the global one in the Assembly API?
  • Ethan_KEthan_K Member, Onshape Employees Posts: 57
    Hi @C_Justin
    All the transformations returned are in reference to the 'global coordinate system' (just the assembly's coordinate system), however the coordinate system of each mate connector can also be retrieved, and so, AFAIK, you could get the transformation WRT the mate connector given those two transformations. Could you explain in a little bit more about what you are hoping to do?
