New FeatureScript: Hose Routing
sebastian_glanzner
Member, Developers Posts: 497 PRO
Hello Everyone,
Good News! I'm releasing my Hose Routing FeatureScript:
https://cad.onshape.com/documents/54d06a3b8abd1fcb0daba26b/w/00a336bf184d3800f0194a5c/e/e689b647e557695970d3d603
The FeatureScript uses Arcs and Circles as input (either from solids or sketches).
You don't need sketches at all, which makes it more efficient if you want to create hose routings in context.
Usage:
Thanks for the help, support, inspiration (Wiring FeatureScript
) and motivation:
@Jake_Rosenfeld
@ilya_baran
@romeo_graham392
@owen_sparks
@MBartlett21
Usage:
- Select the start of the hose
- Select the end of the hose
- Optional: Add midpoints between start and end (in the correct sequence)
- Use the flip direction buttons if the assumed direction is wrong (only start and end)
- Choose a hose size or use the "Custom Size" Button
- You can also edit the straightness but normally this is not necessary
- Try to use different "Mid points"
- Flip the direction at start/end if necessary
- Make sure the hose does not intersect itself
@Jake_Rosenfeld
@ilya_baran
@romeo_graham392
@owen_sparks
@MBartlett21
Nice job @sebastian_glanzner. Might consider adding array parameters so you can nest multiple Hose routes in one feature. Love this.Lou Gallo
Sr. Director of Product Definition. UX and Support0 -
This looks wonderful, I'm enthusiastic to try it out tomorrow, thanks for making it public.
Owen S.Business Systems and Configuration Controller
HWM-Water Ltd0 -
@sebastian_glanzner Good work and I really like using this feature for flexible tubing or cable routing with certain types of cable.
Can I request some updates to it?
I would like to be able to re-order mid point selection similar to how the loft command has right now. It would be very useful for changing midpoints without having to clear the selection.
Regards, Michael1 -
@sebastian_glanzner should be able to use the
ALLOW_QUERY_ORDER
UIHint to allow query reorder. To learn more please see the UI Hint section of our documentation:
https://cad.onshape.com/FsDoc/library.html#UIHint
Onshape, Inc.1 -
@michael_mcclainThanks for the nice feedback. I am very happy that the feature is useful and hopefully saves a lot of time.
I think your improvement idea is very good! I have updated the feature!
1 -
@sebastian_glanzner thank you very much! And thank you to @TimRice for the help. That change makes the feature a bit more robust when facing downstream changes.
I have a question about the feature. Is there a reason why you can select the ID and OD of the tube, but the geometry only shows the OD? Does it create self intersecting geometry when it Calculates?
I think the feature is great and I end up using it a lot in my design work.
Regards, Michael0 -
The ID is used only used for internal calculation of the density/mass.
When I developed it I also used the ID for the inner geometry but the sweep command was quite time costly.
This is the only reason.
Can you share a screenshot of some your work?0 -
@TimRiceTimRice said:@sebastian_glanzner should be able to use theALLOW_QUERY_ORDER
Will this UIHint get added to the 3d fit spline command at any point? It would be very useful0 -
@sebastian_glanzner Could you please add icon?
@Krz Icon added
1 -
nice :-) It's easier to find it on the list now. Thank you
@MBartlett21
We actually did an audit this dev cycle to find features where selection reorder is useful, and added it in where appropriate. This will be released in our next release. 3d fit spline is included.Jake Rosenfeld - Modeling Team5 -
@MBartlett21
This has now been released for the selections we thought were appropriate. Feel free to let us know if there are any we did not make reorderable that you think should be.
https://forum.onshape.com/discussion/12157/improvements-to-onshape-august-20th-2019
Jake Rosenfeld - Modeling Team2 -
@sebastian_glanzner Thank you for the feature! It is excellent. Could I make a request, please? We are routing some hoses, and it is important to respect a minimum bending radius. This way, we can avoid the tubing from kinking. Would it be possible to set a minimum radius for the hose routing?Thanks again for an excellent feature.0
@andres_dandler Thanks for the feedback!
About the minimal radius:
I'm not sure how to solve this. I think I would have to start a query that finds the smallest bend radius of all splines.
I don't know if there is a command for this.
@TimRice
Is there a command to find the smallest bend radius on a spline?0 -
I checked in with our internal FeatureScript team and @paul_chastell suggests calling
evCurvaturealong a number of samples on the curve to get the largest curvature. Then 1/curvature = radius of curvature. Keep in mind this is an approximation. @ilya_baran also mentioned you should check tangency along the curve to ensure you do not miss small high curvature sections.
Onshape, Inc.0 -
@sebastian_glanzner
FS does not have a way of finding min curvature radius, but there is evEdgeCurvatures, that you can call in multiple points and maximize curvature over that. You can do several iterations refining at promising areas.0 -
Onshape is able to calculate the min. Radius by showing the curvature, which is really cool!
Is there really no FeatureScript function?0 -
@andres_dandler I made a big update for the feature! It took me longer than I expected, but it was worth it!
- You can set an custom minimal bend radius.
- This feature extracts the minimum bending radius of each segment.
- The smallest radius is displayed as info text when editing the feature.
- If a bend radius smaller than the "minimum bend radius" is found, a warning is displayed and the feature shows a red question mark.
- Any segment that violates the bend radius is also highlighted in red.
Thanks for your tips about the evEdgeCurvature :-)2 -
@sebastian_glanzner
I love all the UI/UX hints you added in. Nice work!Tim Rice | User Experience | Support
Onshape, Inc.0 -
WOW great job Sebastian! very usefull0
i'll be giving this a tray thanks0
HWM-Water Ltd1 -
Nice one! I won't edit, just for context.2
Wow! @sebastian_glanzner, this looks great! I will give it a try. Thank you so much!
-Andres1 -
@michael_mcclainI have published an update of the FeatureScript. The inner surface is now displayed!Instead of sweeping a ring, which increases the regeneration time, I used the shell command, which is much faster!
6 -
awesome! this is really cool. For my project, a humanoid robot, we have hydraulic hoses routed around joints. I am trying to make sure they dont change length as I look at different joint positions.
I can position the joint however I want in the part studio using variables. Is there a way to specify length of hose, such that its length is kept constant at different positions?
1 -
you can define the length of an arc or spline simple by adding a dimension.
Thanks, I used that previously and I was able to build a somewhat decent sketch for that...but it cant be in 3D, only 2D. My question was whether the point-driven spline from the Hose Routing FeatureScript release is able to also have a total length defined.
@victor_ragusila
At the moment, you can configure the straightness values manually to get the same length in each position.
I'm not sure how to do something like this automatically.
I created a small example and I can see why it is necessary to have a constant length for each position
https://youtu.be/Sv5iEK-IEzw
