While we are on subject, where lies the reason that response time is slower with Onshape than for example Alibre?
I have now these both running side by side on my screen and Alibre is just snappier and feels more accurate to control. It's not about movement speed (that can be tuned in settings) but response time, we are talking about milliseconds here.. It's like throttle response on motorcycle, doesn't show on paper but makes a noticeable difference in handling.
I'm not familiar with Alibre but I believe you may be comparing a web program (Onshape) running in the context of a web browser with a native program (Alibre). The web program interfaces with the 3D mouse driver using the loopback network adaptor. This means there are a few extra hoops to get from one end (the hardware device) to the other (the target program) leading to an increase in latency.
For the most part, the increase in latency for a web program such as Onshape (where the graphics triangles are also managed locally) is negligible but if you do a side-by-side comparison, the difference is expected to be noticeable.
I attached some images of a quick example of what I mean below:
Thanks!
I've been having issues off and on with 2 sets of Spacemouse Wireless (using wired connection) and Cadmouse setups - one at home and one at work. I too am familiar with regular driver stop/starts (be sure to Run as Admin when you restart) etc. I opened a ticket a while ago with their support - Here's the help they gave me and at least that has reduced it from showstopper to medium annoyance!
Try exporting and resetting the current config settings to clear any files.
To do this:
1. Open your 3Dconnexion Home panel
2. Select settings
3. Click on more
4. Click on export settings. Save this to a place you can easily find.
5. Once you have done that, reset to default, and see if that fixes your issue.
If that doesn't work, then I would like to try a full clean uninstall and reinstall. This is a more indepth way than the standard uninstall and reinstall. To do this, please follow the instructions in the link below:
https://www.3dconnexion.com/faq/28
https://www.youtube.com/watch?v=INC60aZlxeY
Twitter: @bradleysauln
