Exporting stl file and printing.
Another Onshape user and myself have been having issues with the stl files when exported from Onshape. We both have 3D printers but he uses Cura and I use Simplify 3D as slicer software. His problem is when he sets the units for inches and exports in inches the files come into the slice program as very tiny images. He has also had the same problems when using millimeters. My issues are that I set the dimensions of the part to be smaller than the bed size but when I import into Simplify it creeps over the edges. Can anyone shed some light on these issues?
If you'd like to post links to your file and the other one too then I'm sure we could take a look.
O.S.
