Assembly pattern configured suppression not working as expected
Cris_BowersCris_Bowers Member Posts: 281 PRO
Just a minor annoyance, but the right click suppress/unsuppress functionality is disabled when an assembly pattern has its suppression state configured. The option is there in the right click menu, it just doesn't do anything when selected. I use right click suppress/unsuppress with parts and surfaces just fine, even when they have their suppression states configured. With patterns though, I have to open the table and navigate to the pattern and check or uncheck the box instead.
    @Cris_Bowers
    Thanks for the report.  I have pulled a ticket for you.
