"For Each" feature in Onshape?
This could be an improvement request or feature script thought, but I've been noticing that there are a few features that I have to set up multiple times, when really I'm doing the same thing. For example, I need to make a new feature for every "Fill Surface" call, even if I want to use the feature on a hundred individual curves. Is there a way anyone could think of to create a "For Each" macro, that can take any feature and simply apply it individually to selections? I haven't thought this through and there might be problems with handling a lot of edge cases (like, what if a feature requires multiple inputs, like an array parameter) but I figured there might be a way to pass those into a nested array parameter.
Does anyone have ideas, or would this be a useful tool?
Max
Max
1
