Why is it not possible to "Derive" a part from "Standard content"?
StephenG
Member Posts: 383 ✭✭✭
Is this an oversight, or is there a good reason why data in the library from "Standard content" cannot be derived into a Part Studio?
Note: When a part is imported from an external supplier via an Onshape App its geometry can be modified and it can be derived.
mahir
Member, Developers Posts: 1,320 ✭✭✭✭✭
Agreed. It would be nice if there was a Save Copy feature for standard parts, or something to that effect. In the meantime, there is a workaround. Put the hardware you want to modify into an assembly. Export that assembly - preferably as a parasolid. Then import that same parasolid into a part studio. Now you have the part and can modify it as needed.5
@pete_yodis for me standard content is part of the design process. Dimensions of bespoke parts need to take into consideration what standard content is available.
So for thread engagement will my bolt engage half a thread, stick out the back of the part and foul something else, or will it be just right?
"Do I stock this standard content?" is another consideration.
Standard content in the assembly is for me too late in the design process.
With this in mind I'm building a company standard content FS. It's nothing more than a "curated derive to here" but allows us to design around what we think of standard content, fixings, electrical connectors, housings, magnets etc.
Cheers, Owen S.
Regarding standard content today, do you use the part number capability for your own needs? And along those lines, do you prefer to see all of your part numbered content bubble up to take priority over new content you may configure?
Regarding what I was trying to accomplish...
I wanted to create a variant of a #8-32 truss head screw so it could be inserted through a narrow rectangular slot, rotated 90 degrees to grip the underside of the slot.
I shortened the length to reflect what had to be done to the 1" long screws I had on hand. I do a lot of cobble engineering-make due manufacturing. I model the As-Is condition of something that is broken, needs improvement, or is an off the shelf part that need to be modified to suit my needs. I use Onshape to help me think through/document the process I need to perform; I am not your typical user and use Onshape in non traditional ways.
Regarding Standard Content...
Standard Content is nothing more than a 3D cartoon (Clipart) that is used to communicate a general concept for using an off the shelf, 3rd party provided product. The precise determination of what item is needed to fully meet the requirements of the product being designed and from whom, is something that usually comes later. The ability to assign a part number to an instance of a Standard Content component is something I would never use. For it to be useful it would have to have many more additional fields to capture vendor source information that would propagate into the BOM.
I believe it makes sense for a company to create their own "Standard Content" parts libraries of approved parts, from approved vendors, and have a well defined process in place to manage the library. Different disciplines, especially procurement, needs to have its hands in the process. How about Onshape provide the tools to facilitate that process.
I use Standard Content, but I find it cumbersome to use.
1) The process is slow. It is as though Part Configurations are being used to dynamically build the 3D geometry representation on the fly every time data is pulled from Standard Content.
2) All the inputs field are fixed lists. If the parts are being built dynamically, some fields should allow a range of user input values.
3) Selecting the desired screw head type is difficult. Why aren't industry standard names used along with Type 1, 1A, etc. The 2D graphic representing what will be inserted is not accurate.
And yes, an easier way to filter for your parts and not things that have not been used yet by your organization seems like a reasonable request and one we have heard and know we need to provide.
Thanks very much for the feedback.
They are just public documents that are not available in the normal search context.
I made a quick featurescript to show its possible. The problem is that its a bit of a pain to setup for even just one part, you need to run a few API commands to get the information required.
If you are desperate for a work around, put the standard content into an assembly, create an in context part studio, and then linear pattern the part into a part studio.
@Caden_Armstrong any chance you've got those API commands handy to share for someone looking to yoink some standard library content into a custom feature or two?
i think I tried this again recently and ran into an issue. Might not be possible anymore?
Dang that's a shame. The document you originally linked is still public though. Maybe the same functionality exists under different commands? Or maybe they realized that the old method you used was a security hole and they went ahead and filled it.
