Circular corners square
lujain_al_marhabilujain_al_marhabi Member Posts: 7
Hello,
I am not sure how to phrase this question. I know how to draw rounded rectangles/squares, however, I am looking for something like in the photo. I tried using Fillet Sketch and 3 point arc but it wasn't working. Probably I used it in the wrong way. Do you mind showing me how you would go about this with pictures please. Thanks.
  • mahirmahir Member, Developers Posts: 1,317 ✭✭✭✭✭
    edited March 2019
    Sketch a square/rectangle. Next, offset that rectangle inwards, making the offset construction. Then, add 4 circles centered on the inner rectangle's corners. Add an equal constraint to the circles and dimension as necessary. No trimming required. When you extrude the sketch OS will extrude the whole profile.
  • lujain_al_marhabilujain_al_marhabi Member Posts: 7
    Thanks a lot that works!
