Onshape Stopped working on Firefox at Uni
giovanni_contreras
Member Posts: 3 EDU
Hello,
It's been a couple of weeks that I can't use onshape on Firefox at the University where I'm working at. Just wondering if there's anything I should know before I try to ask IT if they have any clue.
I can still use it on Chrome, but I don't use Chrome and I'm not planning on using it.
The Firefox version is 65 (64bit). Once again it used to be working fine until a couple of weeks ago.
Attached is a screenshot, basically when I click on 'sign-in' on the Onshape home page, it seems that the sign-in page is trying to load, but nothing ever shows up on the screen.
G
Thank you.
Br
getEditedConstants https://cad.onshape.com/js/onshape.96871e51.js:1 e https://cad.onshape.com/js/onshape.96871e51.js:1 getManager https://cad.onshape.com/js/onshape.96871e51.js:1 l https://cad.onshape.com/js/onshape.96871e51.js:1 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:1 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:32943 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:32943 f https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:32943 f https://cad.onshape.com/js/onshape.96871e51.js:2 t https://cad.onshape.com/js/onshape.96871e51.js:2 r https://cad.onshape.com/js/onshape.96871e51.js:2 <anonymous> https://cad.onshape.com/js/onshape.96871e51.js:32943
Error: [$injector:modulerr] Failed to instantiate module Woolsthorpe due to:
[$injector:modulerr] Failed to instantiate module jm.i18next due to:
[$injector:nomod] Module 'jm.i18next' is not available! You either misspelled the module name or forgot to load it. If registering a module ensure that you specify the dependencies as the second argument.
http://errors.angularjs.org/1.5.7/$injector/nomod?p0=jm.i18next
https://cad.onshape.com/js/vendor.28f62709.js:95:365
https://cad.onshape.com/js/vendor.28f62709.js:95:162129
i@https://cad.onshape.com/js/vendor.28f62709.js:95:161823
https://cad.onshape.com/js/vendor.28f62709.js:95:162100
https://cad.onshape.com/js/vendor.28f62709.js:95:22504
b@https://cad.onshape.com/js/vendor.28f62709.js:95:1356
t@https://cad.onshape.com/js/vendor.28f62709.js:95:22450
https://cad.onshape.com/js/vendor.28f62709.js:95:22520
t@https://cad.onshape.com/js/vendor.28f62709.js:95:2245 vendor.28f62709.js:95:365
e https://cad.onshape.com/js/vendor.28f62709.js:95 t https://cad.onshape.com/js/vendor.28f62709.js:95 b https://cad.onshape.com/js/vendor.28f62709.js:95 t https://cad.onshape.com/js/vendor.28f62709.js:95 Ie https://cad.onshape.com/js/vendor.28f62709.js:95 i https://cad.onshape.com/js/vendor.28f62709.js:95 wt https://cad.onshape.com/js/vendor.28f62709.js:95 bt https://cad.onshape.com/js/vendor.28f62709.js:95 <anonymous> https://cad.onshape.com/js/vendor.28f62709.js:95 c https://cad.onshape.com/js/vendor.28f62709.js:39 fireWith https://cad.onshape.com/js/vendor.28f62709.js:39 ready https://cad.onshape.com/js/vendor.28f62709.js:39 Y https://cad.onshape.com/js/vendor.28f62709.js:39
IndexedDB UnknownErr: ActorsParent.cpp:554
TypeError: conn is undefined[Learn More] NewTabUtils.jsm:1270:5
- Are you able to use Onshape in a private browsing window? https://support.mozilla.org/en-US/kb/private-browsing-use-firefox-without-history
- Can you try clearing out the browser cache as documented here : https://support.mozilla.org/gu-IN/kb/how-clear-firefox-cache ? And then try using Onshape?
