Spirals
Hi Folks,
I just started with Onshape yesterday. Love it so far. I'm an aspiring inventor not an engineer or CAD expert. I'm finding Onshape to be really intuitive.
Now what I'm trying to do is recreate a scroll pump (see http://en.wikipedia.org/wiki/Scroll_compressor) that I did in FreeCad. I like FreeCad but my desktop is just not up to the task when things get complex... or maybe it's FreeCad that is limited, I'm not sure. Nevertheless, FreeCad has these geometric primitives that I can use to define a spiral path to sweep on. Is there something similar in Onshape (yet), or is there another way to do it?
Here's the lower half of a pump I drew in FreeCad.
I saw a blurb about using a helix on a cone here: https://forum.onshape.com/discussion/comment/5073/#Comment_5073 but I don't see how that would work for me. The geometry of a spiral may be different and the top of it in this part would have to be flat.
Cheers
Cheers
jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 665
Looks like you have a 2.5 turn spiral that is flat. What I would do is create a cone that has the inner radius at top and the outer radius at bottom and attach a 2.5 turn helix to it. Then sketch on a plane and project the helix. This remove the z-depth and flattens it into a 2.5 turn spiral. From here I would probably extrude the spiral as a sheet, then use thicken to create the spiral rectangle.
1. Sketch the outer radius on the face you want to attach it to. I chose 4 in.
2. Create an offset plane (any distance as we are collapsing it later) and sketch on that plane the inner circle. I chose 1 in.
3. On a perpendicular plane (may need to create one) sketch a line that pierces the outer radius and the inner radius.
4. Revolve this line around one of the two circles to create a cone surface. (Choose surface revolve).
5. Apply a 2.5 turn helix to the surface.
6. Sketch on the face that you want to attach the spiral to. Choose the 'Use' command and select the helix. This will project it onto the face, which is the spiral we want.
7. Extrude the spiral as a surface the height that you want it to be. I used the default 1 in.
8. Use the surface to thicken and create the surface on the face we want. Make sure it is an "Add" to attach it.
Another approach I had was to sweep a rectangle along the helix and then use replace face on the top and bottom to flatten it.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com2
Anyway, I see what you're saying Jake. I'll give it a shot. Thanks very much
I had one issue though. When I thickened the surface, I did so towards the centre to keep the furthest reaches of the thickened spiral within the outer wall. It didn't work with a thickness value of 1 mm - it didn't thicken at all. It was fine with values of up to 0.75 mm. I didn't see this behaviour when thickening away from the centre. I realize that this is easily remedied by changing the dimensions of the base circle I'm starting with and thickening out rather than in but, as OnShape is in beta, I thought I'd mention it in case it's a bug.
Also, not all spirals are Archimedean like we've done here (http://en.wikipedia.org/wiki/Spiral#Two-dimensional_spirals). I assume other spirals can be defined either mathematically with Python maybe (?)... or doing something similar to what was done here but applying the helix against an appropriately shaped surface based on a curved line. I'm just putting this out there too.
Again, thanks.
Cheers
Turned out the reference bore of the scroll *was* dead true to the spiral, but a couple of burrs on the scroll tips had been missed in the deburring process at the factory (no, it was not from mainland China!)
It was an interesting challenge, working out the true centre from the spiral flanks using only an indicator and a rotary table.
I didn't have to machine a replacement for the scroll, just removed the (very hard to detect) burrs, and it was good to go!
