Laser cut lettering
digtalcarbon
Member Posts: 42 PRO
in General
any simple way to do laser cut lettering on sheet metal parts?
For now I just want to say simple assembly instructions nothing fancy.
(and well done @dave_cowden, that looks like a very solution )
looks awesome! that's a very good point about the dxf, because as we'e discussed in other threads, there's no single-stroke font, which would be FANtastic.
@philip_thomas thanks for the props. I put quite a lot of work into that feature. I'm glad its working well
<rant>
I've kind of missed developing featurescript plugins lately. But I just can't justify the time. Onshape is a REALLY powerful CAD platform due to the extensibility via FeatureScript ( and i'm not kind of guessing at that-- I'm a fluent SolidWorks user too and I can say that using FS plugins is really nice compared to SW). Not to be selfish, but at SOME point if you want people to make great, high quality features, you have to create a model to allow developers to get compensated....
</rant>
Great feature script for text.
Speaking of Stencil style text, I would love to see a feature script with the ability to edit the size of the spacing in the stencil style font. This is useful when cutting out text in parts by laser or plasma.
The minimum space will vary depending on the type and thickness of material you are cutting through.
For example if I were to laser cut an "O" in thin stainless (18GA) a minimum space of .030" will work and all the lettering (internal portion that is tabbed in by stencil) would stay in place. If I were to try this in 1/4" stainless the interal portion of the O would fall out because the heat that is produced to cut through thicker material burns the tabs away.
Currently you are left with the spacing that is placed relative to the height you input. If the spacing is too small I have to manually increase the size of the spacing.
If there was a feature script to set the height and the width of the tab of a stencil font would save loads of time.
Do you guys think there is anyway to do this? I have yet to see a CAD software offer this type of feature.
Thank you
Bryan Lagrange
Twitter: @BryanLAGdesign
The kerning feature is great to maintain the space between the text. What I am also looking for is the ability to control the tabs in the text as well as shown in the highlighted area in the screen capture. Is this possible with this feature?
To modify the spacing you are referring to, I would need to create the fonts from scratch..
I have considered doing that so that I could also support single stroke fonts, but it is a ton of work because of the tremendous number of character sets that would need to be supported.
At some point I may write a font converter that will allow my text feature to import open fonts, but that would be a lot of work as well.
I'm sorry I can't help more in this case!
Thank you for the feature script you have already created.
I would love to see Onshape to be the first to have a custom stencil font generator that you could control height, spacing, width of webbing of font, and width of tab creation. This would be a game changer for those in the manufacturing world that have to Text into metal (or other material).
Maybe @philip_thomas could have this created.
