Is the origin in matedCS in Assembly Definition API a local coordinate or global coordinate?
C_Justin
C_Justin Member Posts: 16
edited April 2019 in Community Support
  • C_Justin
    Just a quick question for this.
    I got a mate located here. How can I then get the location of the mate in the world coordinate system?
    Also,
    It seems in the occurrence's coordinate system, the mate is not at the origin but the API gives "origin" : [ 2.5117617568793384E-18, 0.0, 0.0 ]", why this is not the case that the mate location is relative to the occurence's coordinate system?
  • Ethan_K
    Ethan_K Member, Onshape Employees Posts: 57 image
    Hmm, could you share the document? Then we should be able to determine what is happening! And the coordinate you posted is the origin just with a rounding error because floats, you know! (2.5117617568793384E-18 = 0)
  • C_Justin
    https://cad.onshape.com/documents/f50dce491bdee895ba806f07/w/dd4826567d4b24e3f5922dfc/e/89fa612e49c9bf6a95ef375d
    This is the document, I think the mate connector connects at someplace near the origin but not the origin(not within  2.5117617568793384E-18)?
  • Jake_Rosenfeld
    Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646 image
    @C_Justin
    Our length tolerance is 10 nanometers (1e-8), anything difference smaller than that we would consider 0.
