Center of Rotation
famadorianfamadorian Member Posts: 390 ✭✭✭
In the image, I've selected a point, but when I try to rotate, just a small movement with the mouse and I'm off to disneyland. That's because I've zoomed in much.
Can't I change the center of rotation, so that I rotate where I appear to be?
I want to be inside the model, not a light year from the model with a telescope;).
    move the cursor to the point before rotating.  The center of rotation is base on where the cursor is when you rotate.  It just take some practice.
    www.accuratepattern.com
  • leon_titanleon_titan Member Posts: 2
    Yeah, same need for this. Prefer Fusion 360's rotation. Would be perfect if there is an option to set this. ^-^
