Fully-Defined Assembly Check
S_HansenS_Hansen Member Posts: 5 PRO
Is there a way to check the assembly for fully-defined part placement? I have an assembly that looks fully defined. To check for fully-defined assembly I typically highlight all the parts and drag them in 3 directions to see if any parts move. Nothing moves when I do this (even with parts that are not fully defined), but then if I select individual parts that are not fully mated, they will move. Is there a better way to check for fully-defined assembly mating?
