Fully-Defined Assembly Check
S_Hansen
Member Posts: 5 PRO
Is there a way to check the assembly for fully-defined part placement? I have an assembly that looks fully defined. To check for fully-defined assembly I typically highlight all the parts and drag them in 3 directions to see if any parts move. Nothing moves when I do this (even with parts that are not fully defined), but then if I select individual parts that are not fully mated, they will move. Is there a better way to check for fully-defined assembly mating?
Unfortunately no,
but you can add your vote here:
https://forum.onshape.com/discussion/10158/have-a-fully-defined-indicator
1 -
Grab every part individually in the tree and drag to see if it moves, if that frustrates you I'd suggest voting on the IR @john_mcclary mentioned and hopefully, we can get an indicator of free components sometime soon.0
