Parametrization barrier of manual context update for configured part studios
konstantin_shiriazdanov
Member Posts: 1,221 ✭✭✭✭✭
in General
Imagine you have configured part studio and configured assembly made of parts from those part studio and from some external parts and subassemblies. Now you want to make in-context edits to the configured part studio geometry refferencing components which position or geometry depends on the assembly configuration state. Just was exploring how in-context references behave in case if they include configurable geometry and as I expected you have to each time when configuration changes update the context manually. And it seems like this is some barrier of parametrization originating from manual context update paradigm. The solution I can think about is allowing to configure part studio context itself, or to optionally allow dynamic context update when assembly configuration parameter changes, or some another mechanism which provides linking assembly context to the appropriate part studio configuration.
didn't thought about this worflow before you and Ilya mentioned it, thank you, a good enough partial solution
