Export a Multi-Level BOM to csv
michael_mcclain
Member Posts: 198 PRO
Are we able to export a multi-level BOM from the built-in BOM functionality in an Onshape assembly?
I know you are able to export a flattened or structured BOM, but I want to be able to also view and export a multi-level BOM without having to expand every assembly and then export.
mthiesmeyer
Onshape Employees Posts: 115
Hi @michael_mcclain,
It sounds like you are aware, but just to be sure, from the UI you can:
* Open the BOM table
* Switch to Structured
* 3-dot menu -> Expand all
* 3-dot menu -> Export to CSV
If you would like an option to specify the BOM table type on export please create an improvement request to the right ----->
Best,
Mike6
Best,
Mike
I will still create an improvement request for a multi-level BOM option since I think there is a need for it.
