.onshapepy. key file location (Win vs. linux)
fluvio_lobo_fenoglietto
Member Posts: 36 PRO
in General
Hello,
Have there been any changes to the format and location of the .onshapepy. file for either Win or Linux.
I can execute my programs by adding the file to my C:\Users\<myusername>\.onshapepy.
But I do not seem to be able to place the file in the correct directory in Linux
So far I have tried:
- /home/
- /home/<username>/
- /usr/
Please note that onshapepy is deprecated now in favor of onshape-clients [here](https://github.com/onshape-public/onshape-clients). It is still in a somewhat experimental stage, but can already do substantially more than onshapepy. If you do want to keep using onshapepy, it pulls the config from ~/.onshapepy according to the code: https://github.com/ethan92429/onshapepy/blob/master/onshapepy/core/client.py#L54. So it is wherever pathlib.Path.home() resolves to I suggest running:
Then put the .onshapepy file there!
Thank you!
Will you guys get rid of onshapepy?
I may jut finish-up my code and then look into translating (depending on your plans).
Maybe could you give me some guidance for the translation.
Below is an example of my version of an get/update configuration routine (with my imports and object definitions):
from onshapepy.play import *<br>import json<br><br><div>part_URL = "https://cad.onshape.com/documents/{}/w/{}/e/{}".format( self.did, self.wid, self.eid )</div><div>self.myPart = Part( part_URL ) </div><div>self.c = Client() </div><br><div>response = self.c._api.request('get','/api/partstudios/d/{}/w/{}/e/{}/configuration'.format(self.did, self.wid, self.eid))<br><br># here I make some modifications to the configurations(variables) and then push a payload that it is essentially the payload....<br><br></div>response = self.c._api.request('post','/api/partstudios/d/{}/w/{}/e/{}/configuration'.format(self.did, self.wid, self.eid),body=json.dumps(payload)) I noticed, from a quick glance, that clients has simplified the syntax, so I may just need to translate the calls quickly.
Thank you!
