Help with animating for School Project
simon_dwyer
Member Posts: 8 EDU
Hello, can anyone please help me with my Onshape? I have to animate a model in which when pushing in this:
Will rotate this:
at the same time. Here is a link to the project: https://cad.onshape.com/documents/de5a9ea034f9e95cb6a1f492/w/9a8f152301e919cdd7b08cb8/e/d88d746f838e7ea5ad7582fe .
Help would be greatly appreciated.
Will rotate this:
You can use a Rack and Pinion relation (assuming you are using a slider and a revolute mate)
https://cad.onshape.com/help/Content/materelation-rackandpinion.htm
There is a video example in that help page that Morgan shared, under Desktop and then Video Example. Here is some additional documentation about all of our relations (which is the sort of thing you are trying to get at; motion in mate A affects mate B is a called a mate relation on Onshape terminology):
https://cad.onshape.com/help/Content/relations.htm
https://www.onshape.com/videos/advanced-assembly-motion-in-onshape-03-13-18
