Why does Boolean subtract feature take so long to regen (nearly 10 minutes!)
kevin_radtke
Member Posts: 3 ✭
in General
I used an Onshape tutorial to create a simple part with a knurl. The Boolean subtract feature takes nearly 10 minutes to regenerate making using this part very frustrating.
When the part is first created the features are regenerated reasonable fast (~100-300 ms) but then the Boolean operation takes a dive. Does anyone know what's going on?
Here's a link to the part studio https://cad.onshape.com/documents/1849581b133a92dd551c87b6/w/4f93878b4f3a7d4a70802221/e/79ac65a4a4be486fb0cbd9dc "Test Knurl"
Cris_Bowers
Member Posts: 281 PRO
Anytime you have that many faces on a part like that it's going to take a long time to regen. Unless you actually need the knurl for manufacturing purposes there isn't really a need to show it. The same goes for things like modeling threads on bolts, screws, and the like. There are featurescripts to model cosmetic knurls and threads if you just need some sort of visual representation.
9
When I came across the knurl tutorial video it looked fairly straightforward and did produce the desired result I was looking for (cosmetic knurl for the drawing) and at first it caused no problem, but the performance has taken a dive to the point where it is now an unusable part and often doesn't regen due to "a problem was encountered" message. I just wondered if I did something wrong or what caused the change in performance.
Thanks again!
