Line Drawing - End The Line and NOT Exit The Tool?
larry_hawes
Member Posts: 478 PRO
in Drawings
OK I will test the theory that there are no dumb questions but this has baffled me forever....Is there a way to end a line with the escape key and not exit the tool? I thought I saw a method but cannot recall. If I am drawing a const. line and want to draw another, I hit escape which exits the line and the tool, and then have to re-select the line/const. tool again. Or??
Thank you
Thank you
owen_sparks
Member, Developers Posts: 2,660 PRO
If you're drawing single line (only one segment, not multiple segments joined as a polly-line) then a left click and hold at the start point, then drag to end position and release, will result in the line being escaped and the tool remaining active to be able to draw another line.I'm not aware of a method to draw a multi segment line, escape and keep the tool active. Pressing the "L" key will escape the current line, so a double press will escape and start another...Doesn't really give you the answer you want I feel :-:smile:Owen S.Business Systems and Configuration Controller
HWM-Water Ltd3 -
pmd
Member, Developers Posts: 64 PRO
If you double-click the final point in a Line it will finish the poly-line and leave you in line mode.
If you have already single-clicked and want to end the poly-line but stay in Line just click on the end vertex again which does the same thing.
5
Does seem like it would be cool to be able to escape multiple segment lines with the escape key and NOT exit the line tool. Now adding 'L' to my short cuts.
Thanks again
Curious, are these techniques that most people seem to know, learned through some sort of osmotic interaction with the program? Or is there a source for us boneheads to learn such things?
The 'L' key although it's a very nice 'L'ine reminder really sucks for such things.
Can't be the first one to want customized hot keys? I'll do another search....
Holding the left mouse button through the line draw simply ends the line draw without exiting the tool and double clicking the end of the line ends the line and leave the tool active, at least on my computer.
